DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Exhaust (http://www.ramforumz.com/forumdisplay.php?f=145)
-   -   2.25" Vs. 2.50" Dia?.... (http://www.ramforumz.com/showthread.php?t=168994)
sgreen3 03-02-2014 02:45 AM
For those of you guys that's used both is one really better than the other? My truck is not a speed demon by no means and I am putting headers on it. but the 2.50" kit I found is almost a $100 more. So is an extra 1/4" in Dia worth the extra coin?
Bully's Performance 03-02-2014 04:17 AM
Are you talking about the mufflers? or the headers? I will assume the Headers and not the mufflers as most headers the largest you can get for these trucks a 1 7/8"?
sgreen3 03-02-2014 11:10 AM
Im talking about exhaust pipe size its self.
Bully's Performance 03-02-2014 12:50 PM
If you are redoing the entire setup I would go with 2.25" if you are running 1 3/4 headers, if you are running 1 7/8 headers I would go with 2.5", If you have not already purchased your parts I would be more than happy to work up a quote for you, Do you have any particular parts in mind already? Of are you still deciding on which Manufactures to go with?
Thanks
Jeremiah
sgreen3 03-02-2014 07:15 PM
Well I already have a set of 1 3/4"headers on the way. but just trying to figure out an exhaust system o replace the wore out straight pipes that's currently on there that's rusting out.
snrusnak 03-02-2014 09:24 PM
either will be fine. You won't notice a difference. I'd go with the cheaper.
Graygoose 03-03-2014 10:36 AM
The biggest difference is sound, I have done both, and will always do 2.5" minimum.
sgreen3 03-06-2014 04:54 PM
Thanks kinda what I was thinking. Thanks for the reply!
