DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 (http://www.ramforumz.com/forumdisplay.php?f=86)
-   -   injector swap (http://www.ramforumz.com/showthread.php?t=157384)
R Pope 11-02-2013 05:27 PM
injector swap
I am putting a 5.2 out of a rolled '97 Grand Cherokee into my '95 Ram 1500. All the sensors needed changing over, and the flex plate too. What I want to know now, will the '97 injectors that are for the OBDII computer work with my OBDI setup? Same pressure, flow, all that stuff?
Also, the '97 has no EGR, will that affect the engine in any way? I realise it may make the Check Engine light come on, but its been on for three years now anyway.........
panhead 11-03-2013 01:04 AM
The injectors may have a different connector. I don't know since I don't have the knowledge with Jeeps. As far as the EGR, just swap out the intake manifold. As far as the check engine light for the EGR. If its original, Dodge still offers EGr's for the 2nd gen Ram's.
R Pope 11-03-2013 06:07 AM
They connected up fine. Just wondering if the pump pressures are the same. Guess I'll just fire it up and see how it runs.
Merc225hp 11-11-2013 03:09 PM
The 95 uses 39psi the 97 will be 49psi. It will run pig fat.
R Pope 11-11-2013 05:11 PM
Fired it up, runs crappy. Have to change the injectors, I guess. Oh, well, no biggie. Already changed just about everything else!
R Pope 11-13-2013 08:52 AM
Hooray! Swapped in the early style injectors and it runs great! Seems to have lots more power than the original engine. too. It was probably down quite a bit on compression anyway, even before the head swap made it an oil burner. I'm hoping a few heat cycles will burn any oil deposits off the O2 sensor......
