Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > gonefishin776
United Radio
Conversation Between gonefishin776 and martin5702
Showing Visitor Messages 1 to 3 of 3
  1. gonefishin776
    06-17-2013 12:15 PM
    gonefishin776
    check your oil level. Had this same problem when I first bought my truck. Turns out the dealership didn't put enough oil in it. I takes like 7 quarts or something..i think they only put 5 in or something like that.
    try there. your oil pressure gauge is operating normally.
    you can also try posting this question in a sub-forum, there all the members can see it and not just me
  2. martin5702
    06-17-2013 09:20 AM
    martin5702
    I bought this truck about a month and a half ago. For the past week I keep getting a check engine light. When I run the scanner it gives me the code PO524 (engine oil pressure to low) it resets itself in about 2 days then comes on again. also when I come to a light my oil pressure drops a bit then goes up when I accelerate again. about the same time as all this started I began hearing a little knocking from the engine. I read thru some threads and from what I saw it said many people with a hemi have the same related engine knocking and that it is just something these trucks do. I have no clue what type of oil the previous owner was using but I'm thinking about using royal purple 5w-30 with a mobil 1 oil filter to see if this helps out with the check engine light? What are your thoughts on this?
  3. gonefishin776
    05-31-2013 02:34 PM
    gonefishin776
    Welcome to the board!
    I just wanted to stop by and personally welcome you to this great site. There is so much information and so many great people here.
    Don't hesitate to ask me any questions, if I can't answer them, I'll try my best to refer you to someone who can.
    Kyle
